JustOverTheHill
New User
Ford 532.......still with me? Awesome! Well with y'all's help I have fixed everything on farm so far
Now I'm stuck.
Simply put, can I remove the bill hook pinion shaft with knotters mounted on machine?
I've removed the spilt pin in the pinion gear. Tapped shaft end from rear with a brass punch. No movement, just taps!
If wondering why, I need to replace worn pivot bolts on the twine holders.
Thanks tons for any guidance
Now I'm stuck.
