(quoted from post at 13:20:22 06/30/22) As you may have seen, I tried LeRoy's splicing knot and it was amazing. Worked for me on the first try. A knot approximately the
same diameter as the 9000 sisal. I have not tried it thru the baler yet, but it has to be better than my fat knots. gobble
I tried all three baling last night.
I did my regular square knot... no problem.
I did Leroy's fuzzy splice... no problem.
I tried the fisherman's knot, and just cut it out and remade it as a square knot. Maybe I didn't do it right, but in 7200 sisal, my fisherman's knot seemed to be as big as a golf ball.
I think my issue is my twine discs. They must be worn, or out of adjustment. The baler is tying knots and wiping them perfectly, the only time I've had issues is when the splice knot pulls through (which tests the twine discs, because the splice knot slides hard against the hay in the chamber) and when my bales start to get too tight (which also tests the twine discs by pulling the twine with more friction)
The issue came to a head last night, because what I was baling was so non-uniform. The field had patches of nice dry timothy where I had to keep the bale clamps tight to prevent making puffballs...and the same row might have patches of thick clover, which was "dry" for clover, but packs way differently than timothy... throw in some wild parsnip and goldenrod on the backswath for even more variety... I was on and off the tractor 50 times baling four loads to keep the bales right and keep my knots happy.
My twine balls changed over on the nice packing stuff, no problems there. When I encountered the clover wads though... I had some issues.
It seems that my twine discs have a narrow zone of bale tension to operate in. With the field being so patchy, I couldn't get a feel for what tension to use. Usually, I can just check a few bales on the wagon and combine that with how the tension cranks "feel". That feel wasn't very good. The baler might have a wad of clover in the pickup, one bale of clover tied and a bale of timothy under the tension clamps. The bales in the wagon could be a mish-mash of timothy, clover, other stuff... all good feed at the stage of growth we baled it, but all different when it comes to packing and twine friction.
I took Advanced Calculus in college... so I can recognize when I have too many variables to deal with
