Company Logo (800) 853-2651 Shop Now
John Deere Sulky plow # 268
Duner Wi
06-22-2022 19:28:17
on main plow beam, might be model # 268 or part # of beam.
I would like to know how the tail wheel comes off. Looks like you remove nuts from 4 -7/16 carriage bolts and outer hub should separate from wheel and inner hub. Mine has been sitting out doors unused for 75 years and wheel won't rotate. I got the other 2 wheels greased but this one is being difficult. Thank you.
Duner Wi
06-23-2022 19:53:20
 Re: John Deere Sulky plow # 268 in reply to Duner Wi, 06-22-2022 19:28:17
Here it is apart, just like you described.
Third Party Image
Duner Wi
06-22-2022 20:20:32
Here is photo of tail wheel.
Third Party Image
David from Kansas
06-22-2022 19:34:59
That is a beam number. If the tail wheel is like most of the older trailer plows by JD, You take the bolts out of the wheel and there is a sleeve with a pin through it that when removed, the hub will come off. Might be hard to see the pin as it will be covered with grease. That is the best I can remember. A pretty simple procedure.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
