Gehl 454 hay rake questions
Hello-
Has anyone owned or operated a Gehl model 454 hay rake? This model is run by hydraulics, not ground driven. Is this model reliable? parts available for hydraulic motor? Would Farmall 300 or Farmall 450 hydraulics work to run the basket? Thanks
-Jesse
Should be a common hydraulic
motor.Probalably cheaper to replace than
to be rebuild.It may not even be
rebuildable.However,they are not
terribly expencive.Your 300/450 won't
have enough hydraulic 'poop to run that
rake.Upgrade to an 06/56 series tractor
or add an external power pack.A
pump,reservoir,flow regulating
valve,etc.
Thanks for all the replies and info everyone! I think I am going to steer clear of this rake. Seems like an inefficient way to run the basket on a rake when could be using the ground to drive the basket like normal rakes.
(quoted from post at 17:39:58 01/27/22) Jesse: If your not interested in gehl rake , Could I ask where its located , or contact info I've been looking for a different
Rake like that.. Thanks
It is listed on Facebook marketplace for $900 in Chili, Wisconsin. Hope this helps. Thanks
-Jesse
