Greetings,
I have (well, father-in-law has actually) a New Holland 455 sickle mower, early serial #.
The knife head broke, likely due to a worn out bushing. As noted in many posts on this forum and extensive web searches, the replacement part is NLA. Later serial numbers appear to use the same knife head as NH 456 mowers which is readily available.
So, has anyone tried using the newer 456 knife head with an older 455 mower? Can it be modified to work? I have not been able to find any guidance on this. I did come across a kit to update the pivot drive of a 455 to a 456 which would presumably make the newer knife head compatible, but that is cost and effort prohibitive for such an old mower.
Any advice is most welcome.
