I have read here that you cant bale shredded grass for hay, then I have read that you can with certain small square balers (Hesston 4550/4590/4600, being specifically stated (Case/IH 8545, 8555, 8530a12, Cat Challenger SB36 same types) that you can bale bushhogged grass for hay. Are they able to do this because of longer needle /pick-up teeth? or does the non bushhoged hay apply solely to round balers? The reason for the ?is that I was wanting to use a JD 224 or 336 after cutting with a Woods B320 bushhog.
This post was edited by dwragon on 11/24/2021 at 08:53 am.
