JD FB217C Grain Drill
hiredman1956
New User
With the sprockets set on slow, any idea what the drill should be set at to put on 100 to 120 pounds of triticale per acre? Lost the JD slide rule. Drat
I have a scale that I use to calibrate my drills for all kinds of seeds . If you go on Deeres website you can download a operators manual for the drill and it probably has the seed chart in it . I just use the wheat setting when I drill triticale
Drill calibration scale
