Hi Eaust
Had to do some bearings on the conditioning rolls a 492 slightly different machine however the set up would be very similar. Went to local bearing place and got some Fafir brand which had a wider collar so they would be more durable than what NH wanted to spec. They usually are cheaper as well. As long as you can get the dimensions a bearing place should be able to help you out.
No specifics, but
If you can get one removed, you may be able to get a manufacturer part number off of it...Timken, FAG, whatever..then find those bearings.
If you're replacing all 4, may have to buy one to get a part number off of it....I've done that.
Also, you can type the NH part number...Messicks shows 86575514...and search on ebay. There's one listing there, 3 Fafnir bearings for $99, but they look like greaseable bearings, not sealed.
Good luck
Fred
I have gone to my local bearing store many times with old bearings or pieces of old bearings, or just measurements, and have gotten what I wanted for much less money than OEM.
As others have said, take the number, or the bearing, to a local bearing supply place and try that. Or type the number into Ebay. I've gotten a lot of discontinued bearing off Ebay for $2-3 apiece. You can go online and get much less expensive bearings, but sometimes they are CHEAP bearings. No name, Communist Chinese bearings aren't really very good.
(quoted from post at 06:37:38 09/19/21)
ay attention to this. Generally your OEM bearings are a higher quality bearing. Generally speaking your bearing wearhouse folks can get you a quality bearing. Be careful online though. A lot of fake name brand junk out there.
Google Joe's Machinery,LLC. They have those bearings for 488 rollers at $84 each. That may sound high but I have bought from them before and the bearings that I got were top quality. I got bearings for NH 404 crusher rollers. They are an odd size and could not be found anywhere else.
Garry
