Farmall C24 sickle mower
ronztoys
New User
Does anyone have a parts breakdown for a C24 mower preferably the pitman flywheel and the lower section. I am trying to disassemble the lower section to replace a seal behind the pitman flywheel and can't see how it come apart
Here you go. Remove the roll pin. Unscrew the nut and be careful doing it as the spring is under tension. Slide the flywheel off. the two
ratchet slip clutches come off next. If I remember correctly #7 will screw off of #16 and the shaft will pull out the backside thru the #14
flange. It has been a few years since I had mine apart. Binder Books had the parts manual and the operators manual in stock.
Sorry it is sideways, have a new cell phone and it is taking me awhile to learn to use it.
hey thanks but i need the lower picture where the pitman attaches to the lower flywheel . I managed to get the upper pulley apart with the slip clutch and spring. I have tried to find the parts break down for it but so far no luck.. Thanks for that picture too though.
That is what is at the very bottom of the picture. #25 thru #34. Or the left hand side of the picture I posted. You have to remove the pitman
bearing and there is a nut behind it that will allow the flywheel to come off.
thanks for posting the picture but I really can't see that part all that well. it will not let me enlarge that portion. I will get a picture of mine since I don't see a nut on the lower pitman flywheel
