Wood splitter tire options
JerryLook
I have a home made wood splitter that uses an old VW front axle. It has the 2x205mm space wheels on it. Theyre 4.5 wide. Right now it has some old 5.6x15 bias ply tires that are shot. What are some common 15 tire sizes that will fit on these wheels? I have enough room for wider and taller tires. It doesn't have to be too road worthy. It only gets towed about 10 miles once every couple years.
Not really an implement, but I do tow it around with the tractor. Haha.
(quoted from post at 21:41:44 08/22/21) Most anything 15 would be ok for what you are going to use it.
What do you think the widest tire is that I could get to fit on those skinny rims? I could probably find some used tires somewhere, I just dont want to have problems getting them mounted if theyre too wide.
205-15 would work.
Or buy two adapters to go from old VW to 5 on 4.5 bolt pattern.
Then go to junkyard and get any size tire and wheels you desire.
Like these
Probably find used ones on ebay for less.
