2MaineFarmers
It looks like my feeder tooth spring broke and when it traveled back to shove hay again, the tine came up over the guide bar and wedged on its way to push. It scored up the aluminum feeders and bent one all to hell. Not exactly sure how that happened. I bent everything back and threw an old spring on to keep the teeth pointed down on the return travel. The shear pin on the big front flywheel broke so I replaced it. Went to test everything out and the slip clutch right before the big flywheel is slipping. It's acting like something is still bound up and I've looked all through the drivetrain, gears and chain and can't see anything sticking out at me. Of course I've got hay on the ground all raked and it has to be baled tomorrow before rain. Anyone seen anything like this and have an idea? Thanks a bunch!
