Where can I find rubber mount rake teeth that will last for more than a couple years? The type that go on a1 5/8 inch tube with a bolt thru the top. All I have bought for the last ten years break out of the rubber in a short time. I have some old ones on the rake that have been on it for years and still good. Everything comes from China now and just junk.
I'd like to know that also. I have a Ford 3 point rake that has them and I stopped using it due to the teeth breaking off
Try Shoup parts I have gotten teeth from them and the seem to last well.You might pay a little more but they are better quality.
https://www.shoupparts.com/
This post was edited by mudcreek183 on 08/16/2021 at 06:34 pm.
I've been using a few of these to see how they last and seem to be pretty durable. If you bend one you can straighten it. Haven't broke one yet. My rake is a JD 894 but they are available for most brands like NH Ford Int, and New Idea. You need a clip to hold them but they are reusable so you only need to buy them once at just over $1 each.
The only solution is buying metal teeth with the clips. Has nothing to do with where its made. Rubber simply breaks down.
I have a new idea rake that sheds rubber teeth as well. It helps to make sure all tires on rake and tractor are properly aired up and machine leveled. I am also thinking about the metal teeth.
(quoted from post at 20:11:30 08/21/21) who/what dosnt exist? Shoups? I got their new catalog the other day
Hes saying that a rubber tooth that wont break doesnt exist.
