John Deere 348 Bailer
2carlisle
John DEERE 348 bailer. Has any body used Green Bailers guides or rails that the plunger packer run in. Model 336 and up use the same part Number. Thanks, Carlisle
I'll bet that what you have there is a baler. I haven't used those but I had to remove the ones in my 336 because of rust build-up under them. There was nothing wrong with the guides themselves.
I picked up a mid 90's 348 that was locked up. It had set for 5 years more with wet bales inside. The rust under the rail expand the right one and
caused it to be locked up. The rails are grooved and worn out. My plan is to replace rail and bearing after I grind the rust out and treated with
POR15
I have the fh312232 in the old number e44835 and the fh312295 in the old number e44836. Still need to check on the FH312310. E42318 and FH311771 have been sold previously. All parts are new. E44835 $140 and e44836 $100 plus shipping
