Implement Alley Discussion Forum |
NH 477 Haybine over running clutch weld
Author |
[Modern View] |
Axtell
01-12-2021 04:19:29
I am planning on doing this repair/modification on our haybine. Does anyone have a picture of this fix? Thanks!
Axtell
01-17-2021 05:09:31
Re: NH 477 Haybine over running clutch weld in reply to Axtell, 01-12-2021 04:19:29
Thanks for the response, Steve!
I have struggled a little with this decision, but in my research I have discovered the overrunning clutch was phased out by New Holland. It seems a replacement fixed sprocket/pulley was introduced. With the age of the machine and the amount it is used was also a factor. That being said I am still unclear on the welding technique and have opted to replace the defective pins, springs and recently discovered missing shims/washers on the shaft. Cost was not too bad for these parts once I found them. The missing washers allowed a 1/4-1/2 inch play along the shaft which separated the clutch enough to prevent the pins from engaging. This also caused the set screw in the sprocket to cut a groove lengthwise along the shaft. Thats the next hurdle. https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=implment&th=109529
https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=implment&th=75261
https://www.haytalk.com/forums/topic/47825-477-haybine-reel-overspeed-pins-and-springs/
DeltaSteve
01-12-2021 06:45:43
Not sure what you are asking. Are you wanting to weld it solid? DONT!. It's there for a reason. Or are wanting to 'repair' a clutch that someone else welded ? It was welded for a reason,probably because it was 'broke' and didnt work.Either it slipped,or didnt overrun. Replace it.Overrunning and slip clutches are there for a reason. To protect the machine(s) and the operator.To weld them up solid and likewise modify them is foolish and dangerous,just asking for trouble.An accident waiting to happen.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
560 factory lp has Schwartz wide front new seat all gauges work fast hitch 14.9 38 tires has power steering leak on return side lights work ta works as it should 2 sets rear wheel weights possible trade on other tractors 340 farmall john deeres molines can text pics
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
