JD 350 Drive Head yolk Material
Ive been working on rebuilding my mower and have discovered 2 small cracks in the drive head yolk. I would prefer to stick weld the cracks but not sure which rod to use. Is the yolk cast iron or cast steel?
Thanks
Todd
(quoted from post at 12:33:12 01/10/21) Ive been working on rebuilding my mower and have discovered 2 small cracks in the drive head yolk. I would prefer to stick weld the cracks but not sure which rod to use. Is the yolk cast iron or cast steel?
Thanks
Todd
John Deere is known for using a special cast iron called "nodular iron" aka "ductile iron" in many castings where high strength is required.
The link below from esab has some info on welding it.
https://www.esabna.com/euweb/oxy_handbook/589oxy15_4.htm" Got any photos of the cracked area?
WOW, my reply sure got mangled!
I'll try again.
John Deere is known for using a special cast iron called "nodular iron" aka "ductile iron" in many castings where high strength and impact resistance are required.
Welding nodular iron
Sure. Here you go.
