riveroadrat
I have to replace these bearings in 2 machines and wonder if anyone has tried putting 3 bearings in that bottom piece. I know it takes two but don't remember if it was machined all the way on the bottom of the yoke. If any of you out there want to keep your wobbledrive box in good shape make sure that you keep any side slop out of it. If you don't the counterweight will start hitting that big bolt just opposite it. They had to put it in backward, if it was the other way the round head of the bolt would give some more room. I washered mine a lot but it still moves around some. Later I will remove the bars and weld them up so the bushing is tight.
