Pork chop 1568
I bought a really clean N H 640 auto wrap round baler at an auction Saturday. the auctioneer stated that it DID NOT need a
monitor/controller to use it. i was excited to get it home and start baling as I had hay down and ready. After greasing it up and
oiling the chains, i loaded the string. i noticed the string cutters above the pick up head. never using this style was curious
how it tied with no power. i did notice the manual trip lever. so i figured i'd give it a try, i could always discharge the bale
if it didn't work. when the arrow got close to the stop position i stopped putting hay in and tripped the manual tie. it worked
perfectly. until it would not stop tying. i figured it needed to go through again. i still didnt stop, it started a 3rd time.
when the tie arms got back to the outside position i shut the baler off. cut the string and discharged the bale. i started the
baler and it still wanted to continue tying. i had to unhook the belt off the right side where it spins the tying mechanism. there
is a slide mechanism also on the right side that does not slide back up to stop the dogs on the wheel. DOES this need to be powered
to make it tie correctly ?
