Low tech baie thrower
Alvin 41
Sold hay to young dairy farmer. Her father is baleing with NH baler and super M. gets over 100 bales on trailers if he stacks some.
[/img:2a52b27c16]
Used mine for a couple decades now. Those baskets aren’t perfect, but they have their pluses too. Get along good with mine.
Paul
I normally get 125-135 bales on my EZ Trail bale basket. Wonderful, low tech tool that works way better for me than a thrower would.
I RAN three of those unit sback when i was doing all small bales to hy -vee grocery store they really work slick once you get them set
correct behind the baler
Question for those that have used a bale basket- do these things work ok with older balers that may not be the baler they were back in the day? The plunger looks like its
pushing a lot of hay when you use those baskets.
(quoted from post at 11:45:04 09/28/20) Question for those that have used a bale basket- do these things work ok with older balers that may not be the baler they were back in the day? The plunger looks like its
Yes, that is specifically why I went with a hay basket. I'm running 60 year old NH balers. Sure, you can put a thrower on a 68, but it's just that much more strain on the old girl. With a basket, you get it set behind the baler and let the chute fill with bales. Then you can adjust the bale tension down quite a bit because the weight and friction of the chute does the same thing as cranking down on the bale tension. About the only thing you have to learn to do is not try and make tight turns with the basket behind the baler, but you can't do that with a kicker either in most cases. They are dead simple to use and for me at least give a better shaped bale than when I just drop them in a field or send them up a chute to a flat rack.
