Gehl 95 Feed Grinder Mixer Screens
Hi all
I recently bought a Gehl 95 grinder/mixer
The machine only came with one screen
Does anyone have some screens they would be willing to sale for it or know anywhere I can buy some
Thanks
The one I have now is either 5/16 or 3/8
Id like to have bigger like a 1/2, 3/4, 1 , 1-1/4
Want to crack corn and wheat for chickens
Grind feed for cows including hay and cob corn
For cracking shelled corn just take the screen out, we've cracked a lot like that.
Never done wheat os can't help there.
We grind a lot of ear corn and actually cut out between the holes on a smaller screen, I'l have to measure the screen we modified to tell what we ended up with, but it works pretty good.
We had done to same to a NH screen when we where grinding with a NH 351.
I have heard before that no screen at all would crack corn good Ill try that soon
Id like to know what size hole is good for cob corn Id try that also for the hay
I use a 1/2 screen for cob corn. It grinds it a little finer than I care for but feeding out of a steer stuffer they will sort out
the cob and just eat the corn if I grind it corser. A 3/4 or 5/8 inch does good otherwise. I too have good results just taking the
screen out for shelled corn.
I might add that you can slow the rpms down a little and it won't grind it as fine depending on the screen you are using. Its is what I do when adding a little shelled corn to my cob corn mix when I'm too lazy to take the screen out.
