FordTractorMan
So, I put in a maximum bid of $475 via the Internet on that Eddins wagon I mentioned earlier (scroll down several messages - pics are there) and ended up winning it. Brought it home yesterday and it augers - at least it should - everything turns and the vertical auger isn't worn very much. Surprised me. It has 56x16 airplane tires on it and I'm wondering if there's a tractor or implement tire that would cross to that size. The tires on it are worn slam out and the nylon cords are showing. Left one needs air and the valve stem is nowhere to be found. Not sure where to get used airplane tires or how much they would cost. Also, still can't find out much info on this unit except that it was made in Stuttgart, Arkansas. Any info experience you may have with a wagon like this would be appreciated. Thanks.
