Picked up a fairly new Unverferth 235 gravity box with 10 ton running gear. It had been bolted on all 4 corners but whoever did it drilled on an angle so the bolts came out close to the bottom. All 4 corners have the wood split near the bottom. About 1/2 of the wood split.
There are also holes further up that will go through the angle iron which is where we are going to rebolt it.
There is a sticker on the box to bolt all 4 corners and ensure they are tight. Im thinking this is what caused the wood to split when it tried to rock.
Is bolting this in all 4 corners the proper way?
