bush hog 126R 10ft pull type TIMING BLADES
I had to rebuild the gear on the side that has the ujoint coupler from the center gearbox. How do I time the blades?
Do I hook ujoint up and then undo the rubber bushings on the other side and get them 90 Degree apart?
I cannot figure out how to put the stump jumper on the ujoint side and pick that up to line up the splines on the ujoint.........
Looks like you just put the ujoint assembly on the shaft from main box to side gearbox.. then undo the rubber side and adjust the other gear box to the one I rebuilt that has the ujoint assembly
thanks
pray for my wife....tracey stage 4 cancer........she needs all the prayers she can get.
thanks
