Ford 903 phd issue
Josuer302
Hello all, I recently bought a ford 903 phd with a 24" auger.
I would also like to attach a 6" or 4" auger from tsc. My issue is that what I believe to be the shear pin is appears to be bent inside the auger.
Anyone have any suggestions on how to remove the bolt or how to purposely break the bolt.
I also believe that the 903 takes 2-9/16 if anyone can confirm that. Thanks
Oh, that generally isn’t a problem here. :)
You must not have any rock where you live?
‘Removing’ the shear bolt happens often enough.......
Paul
[/img:d8e05d0014]
Paul you're saying just find a big enough rock and jam it in and it should finish the job ? I appreciate the advise
Saw off the head. Take a heavy punch and big hammer and drive it out. Try to wiggle the bolt with a wrench before you saw off the head.The
bolt is most likely a more common size. 1/2" would be my guess.
Big punch and hammer. Yes the output shaft is the larger one. Typically TSC just has 2 inch size shafts. I have an adapter for mine so I can use the standard 2 inch. Bought it online, Titan brand, for about $80.
