bush hog offset disc
i picked up a 3 pt bush hog offset disc. it's about 6 ft wide. the serial and model number plate is missing. the sticker on the disc says bush hog indusco if that helps. i'd like to find a couple bearings for it before i take it apart. does anyone have a idea what model disc this could be? thanks for the help.
Just give them a call. They are real helpful and knowledgeable. Helped me figure out what clutched my bstwing took.( has 2 different brands of driveline on the same machine)
i did get a hold of them. while they had a lot of tillage equipment schematics, they were not able to help. thanks.
I did a couple web searches and I don't think your disc has any connection to Bush Hog, beyond Indusco calling it that, from old info found on other forums. Those indicate Indusco went out of business years ago and don't mention it being merged into another company. From what I found, I am guessing you likely have an orphan and will need to tear it down and try to match up parts. Just my thoughts, hopefully someone has info for you.
i believe you're right. a very nice lady from bush hog tried to find a schematic on the disc, but had no luck. however the disc has a partial
silver bush hog model / serial number tag on it, and a pretty authentic looking bush hog stickers that appear to be original. i pulled the
disc apart and measured up what was left of a couple bearings. have them on the way. who knows, maybe i paid $100 for a collector item haha.
This is an old thread, but I wanted t leave this here in case someone else is looking for info.
Industrial Scientific Company, Fresno, Calif (Indusco) is out of business. The produced implements are under The Indusco name. Then they started using Bush Hog as their brand name; some data plates will have both names on them. I contacted Bush Hog in Alabama and spoke with a gentleman who explained that the company has changed hands over the years and no longer has any connection to the original company, but the products made by Indusco and Bush Hog of years past can still be repaired and parts purchased from Domries Enterprises, just north of Fresno. I called and verified that they still make some parts for these older implements.
I'll bet (ball) bearings are off the shelf from a bearing mfgr, not a plow mfgr.. Agri Supply in S. Carolina has a lot of different bearing setups available.
