Converting artsway 500 from 1000 to 540
Noelke
Looking at a good artsway 500 feed mill that is 1000 pto drive. Is it possible to convert these for use on a 540 PTO tractor? Hoping you can just change a pulley..
Thanks
Check the parts list to be sure.
It will probably take at least:
a different PTO connection;
one or maybe two different size belt pulleys on the mill;
a different length drive belt on the mill,
one or two different size sprockets that drive the augers;
a different length roller chain over the new sprocket(s).
