Set Hydraulic bale tensioner
Krgreuel
New User
I have an older Massey 1745 baler that has a fixed or closed hydraulic bale tension system. I had to rebuild the tension cylinders on it, now i need to figure out how to charge or pressurize it. shows to have a diagnostic port that looks like a quick connect. anyone run into this before?
only have one set of hydraulics that operates the lift gate. The tensioner is a closed single action system that has a pressure regulator that controls one side, the tension side. When the gate is lifted it is a mechanical action that "resets" or pushes the fluid back to the high pressure side. It does have a cap at the top of the cylinder, I don't know if that is a fill port or not.
