Matt from Oz
Hi HD
What you need to know would be in the service parts book. I have one for a 492 so similar to 489. You could look online on the NH website and hopefully see it in the parts drawing. Just checked and the manual is not a whole lot of help. Obviously you need one for the right hand end part no
577311 and a high one to accommodate the knife head part no 288074 and it indicates 15 of 287458 and 3 of 850135 which makes no sense to me, this is for stub guards only which is the only cutter bar shown in the manual. Just had a look at my machine and there are 8 hold down clips. If you
start from the right hand end (as if sitting on the tractor) you have right hand side clip then skip a bolt hold down clip skip two bolts hold down clip across toward the knife head. I don't appear to have a high clip near the knife head don't know what happened there but it certainly works. There are
spacer plates called shims under the hold downs I reused these. Went for genuine parts as aftermarket where not available, one big difference I did notice is the genuine guards are a lot harder than the copies so should last longer but do cost more. Can I suggest you look at bolts for the knife
sections as these are so much easier than rivets.
