NH 311 Baler information
BearGap
I have a New Holland 311 baler with a model 70 bale thrower driven off the PTO by a belt that goes around the baler flywheel. After a bad bearing on the drive roller of the thrower belt caused the serpentine belt to jump off the pulley, the main drive belt broke. That belt is around 106"x1" V, but I find no part number reference in either of the equipment manuals. Does anyone have a reference number so i can find another belt? Also, any information on the bearing closest to the drive pulley on the thrower belt? Thanks.
the belt is part no. 164528. the bearings are all common sizes if you take the pieces any implement or parts house should be to match it. you can get parts manuals from Jensales in minnesota.
