The international 440
SVcummins
Performed perfectly didn’t even clean the straw out of it last fall or clean the knotters and a bird made a nest under the knotter shield . Greased it last night and cleaned the knotters and put it to work broke two bales one after it shoved the two hundred pound straw bale out and one after I shoved it a little to fast got two more little fields I need to bale then I’ll clean it out grease it and park so it isn’t sitting with old hay in it until next time
Someone is a bit optimistic about the baler capacities I’d say 542 bales an hour would take perfect conditions I’d think
1.40 I think . Little field I plowed for a guy a couple years ago and he Finally got something planted in it and got it to grow . Getting ready to do an 80 acre piece for him that I plowed 2 years ago and then he just let it sit going to take a lot of work to get ir shaped up to a seed bed almost be easier to plow it again then work it down
That’s an amazing outcome anything over a 1/4 ton Is pretty good especially down in this end of the valley up in the higher country you’ll get a lot more moisture and it’s cooler things really grow there
