New holland 499 pto hutch mounting distance?
mmidlam
Putting the 499 on a different tractor. What is the recommended distance between end of pto stub to center of drawebar pin?..can't find my manual
You need a drawbar 'extender'. You need more room/length than a standard pto distance,because of the pump hanging on there. I have mine mounted so the hoses are relatively straight when cutting. At a standard drawbar length,the hoses tend to get kinked,and the pump can get damaged when turning tight on the ends.My drawbar is extended 10" beyond the normal 16" spec for a total of 26" from end of pto shaft to center of the hole/pin in the drawbar.The extra length will also allow you to turn your tractor 90 degrees to the swather tounge. If/when you find your book,the drawbar extender will be shown. You can make one from a heavy chunk of bar steel.1"x2 1/2,or 3" will do,Drill 2, 1" holes,and 0ne 3/4" hole in appropriate places.
