Cockshutt 30 3pt hitch options
T-Nason
I have a 1950 Cockshutt/Co-op 30 tractor that currently has a standard swing drawbar. I've looked online for a aftermarket 3pt hitch to install but it seems most manufacturers of said kits neglect to make one for cockshutt. Is there a kit I could use from a more popular brand such as Farmall or JD?
(quoted from post at 15:56:20 07/03/20) Where are you located I have a parts 30 with the 3pt box under the seat with the rock shaft.
Im in Northwest Ohio. Does it use the standard hydraulic pump?
