NH baler tires
DD in WA
I have a NH 271 baler that needs some new tires. I found a replacement for the smaller 5.0-15 but can't seem to locate the larger 6.4-15 (6 ply). Will a 6.7-15 (6 ply) work? They seem to be available.
aizes are actually 5:00x15, not 5.0x15, 6:40x15 not 6.4x15 and 6:70x15 not 6.7x15 and yes a 6:70 will work just fine as it is only 3/10" bigger. You have to go to a low profile tire to list it like you are doing as in say a 9,5L tire. The way you are trying the sizes could make you not finding the correct size tire. You should actually be able to go to the 6:70x15 on right side instead of the 5:00x15 and a 7:60x15 on plunger side with better flotation.
Used automotive tires make great low cost implement tires.185/195/205x15 and 225/235x15 will serve you nicely.They will fit the rims and will be the 'right' size.
Don't know if the car tire would be heavy enough as they would be 4 ply rating and his orignal bale chamber side was a 6 ply. Now a light truck if avaible in that size might be good.
Got my new tire from miller tire. Found them online. Cost was close
to $100. Cheaper than other tire dealers in area.
