I was given a Bush Hog and I cannot find an ID plate on it anywhere. It is Yellow in color which makes me thinks it was for a county/city sale?
It is 8 feet wide,PTO driven, two cutting blades with swivel cutting tips.
The right hand drive shear bolt is sheared and the flexible coupling is torn.
I was able to photograph a partial name pressed into the "car-tire" coupling material.
The coupling is 6" in diameter with a 2" hole in the center. The bolts appear to be on a 2 1/4" center to center?
The sheared off bolt I think was a 9/16x20x3 and threaded on the bolt head side with a smaller shear shaft going through the drive shaft.
Please help,I really need the parts.
