New Holland 688 round baler
Olly1850fan
New User
Having trouble with drive roll on baler, cannot seem to get the flange bearing off the shaft to be able to remove roller. Any advice appreciated!
Yep, flanges are cheap compared to time. Might use a dremel on the bearing with cutoff wheel. Wear safety glasses
when using a chisel after dremel.
We had that thought just hated to ruin the flange but definitely seems like the better time saver. Thank you for the advice.
Torch it flanges are cheap even expensive flanges are cheap
just hold the tip of the torch so it cuts the bearing and not the
shaft . If it’s stuck that tight you probably won’t get it off
anyway without ruining it
