Mounting Brackets for JD146 Loader on a JD 2755 Tractor
Michael2110
New User
I recently purchased a John Deere 146 Loader to go on my 1992 John Deere 2755 Tractor. I am having a bit of a time finding the Mounting Brackets/Kit to affix the loader to the tractor. Does anyone know how I might go about obtaining these, or at least to see what they look like to know if what came with my loader will work or not. The gentleman that purchased the loader from said he didn't know what it came off of, he obtained it from an estate auction.
I'm working on getting a 148 on to my Oliver. It came off a 4020 RC but there were different brackets for utility and regular models. Check the Deere online parts
catalog.
You have the good brackets as they go back under the axle. The front will bolt up in front of your engine and the rest goes back under the axles. Deere used a special plate and some u bolts to connect it under your fenders. Tom
Very Much Appreciated. Now that I know they are the correct style, and 'The Good Ones', I will take them to work and have them blasted and the step repaired. I am new to this and I do appreciate this Forum and everyone here. I always receive good advise and information from good people. I can get the U bolts and hardware from the Deere Online Catalog mentioned by Mike (NEOhio) above.
(quoted from post at 11:03:43 06/23/20) You have the good brackets as they go back under the axle. The front will bolt up in front of your engine and the rest goes back under the axles. Deere used a special plate and some u bolts to connect it under your fenders. Tom
Ditto what Tom stated those brackets in your photo should bolt up to 2755.
One additional thought. Does your tractor have the engine frame rails? Even though that loader would mount without them I would add a set if it was my tractor. Just makes everything a bit stronger. Tom
I'm not sure what you mean by the engine frame rails. I guess I would have to look that up. The only additional thing that I am going to have to research is how to hook up the hydraulics. This Tractor does not currently have any remotes or hydraulic ports. It has never had a loader before nor any rear hydraulics
Attaching FEL control valve to JD utility tractor has been discussed on this forum many times. Photo below shows how to attach.
Shown below in photo is side frame & part #
I appreciate the information on the FEL connection. I was told that it would cost me about $1500 to have it done... that is definitely not in my budget. I went back yesterday and looked, and my tractor does have the side frames already attached.
