The gear on the back side of the wobble box broke off the bolt snapped off, and the chain bound up between box and the frame. Is this something that will be repairable? What all needs to be removed to get the wobble box out? It looks like there are the two 15/16 bolts at the bottom and maybe 2 mor bolts that may be threaded into the frame. Is there anything I can do in the future to prevent this from happening again. Any input will help was told the NH492 was a good piece. Not sure how it happened didnt make it 15 acres from the time I bought it till it broke. Not sure what lead up to it breaking I was not there. Was pulling it with a MF 175 my FIL was the first to run it. Not sure how fast he was pulling it. Just got a phone call and said the pick up rake quit turning and it was all plugged up. Any knowledge, insight, or wisdom is appreciated.
Thank you,
Doug
Thank you,
Doug
