Grass boards
SVcummins
What are you guys making grass boards from ? The one I had was an inch thick but I can’t buy an inch thick piece of wood will 3/4 do ?
You can get 1" thick lumber at the Jensen Lumber Company in Ovid, Idaho. Sawmill produces lots of rough sawn lumber.
Factory made that I have seen were all 3/4" thick. I know what I saw was factory made Deere as the leaping Deere was painted on over Deere yellow,
The one I had was a Massey Harris it got broke over the winter because I forgot to take it off . Maybe I’ll just get a 1x10 and my nephew can cut it out
Lowes sells what they call a 5/4 treated lumber. It is a smooth board that is 1" thick. I used these for trailer flooring.
"[b:654c4848f0][i:654c4848f0]What are you guys making grass boards from ?[/i:654c4848f0][/b:654c4848f0]"
Back in the late 60's, my dad and I tore down three old houses for the lumber.
There were several true 1" boards.
Found a short piece to cut from an original pattern.
Take a look at the photos below.
a255830.jpg" width="650"
a255831.jpg" width="650"
a255832.jpg" width="650"
a255833.jpg" width="650"
Take a look at the photo below of the measurements.
a255834.jpg" width="650"
Hope this helps.
Ash or hickory is my understanding guess , I’m just guessing , not sure if factory one was that picky
And I have one that looks like that design for a new ideas 💡 they look like a match . Last I looked the new ideas has a few limit supply around varies dealer.
If you have a part number plug into part search of tractor house , it willlocate for you.
The one you made is very well done , I like it .
I think you can order a wood pieceinch from varies Amish mills in the Middlefield Ohio area.
That helps a lot . Wish I had the original metal pieces but I have the ones that came off the Massey Harris board . There’s a guy on eBay who makes wood grass boards for 49$
I see a few for sale on eBay and the tractor magazines but I think I can make one that will be ok for working mower a cheap decal and some paint I think It’ll look ok
On the mower we had when I was growing up the board had met its demise many years earlier. Dad had bolted on a piece of steel rod about the same length as the board and at about the same angle. We used it that way for years. Seemed to work OK.
