Massey Furguson 925 Haybine
Shemuel
New User
I have a Massey Ferguson 925 haybine but when I run it at high rpm the blades hit the guards. Any Ideas of whats wrong?
we had a 925 was a good machine don't quit under stand when you say blades hit guards?what shape is the sickle bar bushing in might be bad that the sickle bar is traveling to far in the stroke so it is passing the guards and catching them is it on both ends of the stroke or just one side. is the sickle gear box bolted down tight
one more thing is the sickle indexed right and is it the right sickle did you just get the haybine or have you had it for sometime and this just started
i discovered the problem this morning. One of the "guards" was not bolted down properly and thats what was causing the blade to hit. Thanks for the advice though.
