tractorsam
I have a CM 165 drum mower I bought used and have no history on. Overall it’s in reasonable condition and shortly after I got it I attempted to use it after putting new blades on it. It worked great for a little while and then started making a ticking noise I could hear from inside the cab. The source of the noise appears to be the blades making contact with the opposite drum when the pass by. At the time I thought a bearing went and caused one of the drums to shift. I’m finally getting to it now and after some disassembly I can’t find any issues apart from the blades touching the opposite drum which I assume they shouldn’t? Anyone that’s played with one before have any ideas? Thanks, Sam
