Company Logo Shop Now
TractorLinks.com
Disc mowers
4010 puller
06-02-2020 14:54:56
Hi guys Iím in ohio here and sold my old 7 foot haybine, Iím in the market for 7-9 foot disc mower. I see lots of them for sale but wonder about parts availability? Iíve heard the old long/farm trac can be iffy on parts. What about pellgro, fort farm Maxx, enrossi, etc. Iíd like to be able to get parts for years to come and not just a cheap throw away mower.
Thanks
showcrop
06-05-2020 05:09:49
 Re: Disc mowers in reply to 4010 puller, 06-02-2020 14:54:56
Another consideration when using a disc mower is that it gives you the capability to get double the amount of hay rained on as you ever have before.
Shaler
06-04-2020 16:31:11
4010, I will try to read between the lines as you omitted maybe the most important part of your question - and that is what is your budget? I will try to read between the lines. You got rid of your old 7 foot haybine. From that comment and the fact that you mention a lot of off brand machines, I have to conclude your budget is not all that high. I dont see you writing a check for a good Krone, Vermeer, or Kuhn disc mower as other posters have mentioned. Watch out for a New Idea disc mower, they are reasonable and parts are available.
4010 puller
06-05-2020 04:00:51
 Re: Disc mowers in reply to Shaler, 06-04-2020 16:31:11
Yea I may consider a good used one but 10-12,000 for a nh Vermeer or Kuhn wonít be happening, I mow 30 acres of hay a year. Thereís just so many brands of mowers out there anymore itís hard to decide good or bad but my main concern is parts availability on the cheaper ones.
Tx Jim
06-04-2020 03:35:51
If disc mowers are all ""copies of Kuhn"" as you state please explain this?
Kuhn/JD/Krone/Kubota cutter bar internally where gears are located is a common housing IE open for oil to flow from one end to other end of cutter bar & cutter bar oil level is checked at one location.
New Holland & Vermeer plus probably some other cutters have individual segments on cutter bar that require oil(lubricant) to be checked at each segment.
Thanks,Jim
ptfarmer
06-03-2020 22:02:45
We got a Vermeer TM800 it's been a really good machine https://www.youtube.com/watch?v=UtrB0m3up6M
RayP(MI)
06-03-2020 18:00:10
Look into drum mowers.
Texasmark1
06-07-2020 18:19:03
 Re: Disc mowers in reply to RayP(MI), 06-03-2020 18:00:10
I am on my second drum. Bought because every used disc had brazed cracks all over the bottom with oil leaking out and too many parts. Cuts grasses great, leaving about a 1" stubble on tough stalks and 2" on small stemmed grasses which is ok for them.
Swore I'd never do it again, but bought a haybine (Ford 538) this year to do my SS hay crop. Need 4" stubble for a decent regrowth and no disc or drum I've seen can give you that. Did the first cutting last week and regrowth is fantastic, as was the cut.
495man
06-03-2020 16:41:16
Kubota has three blades, they bought Vicon so that's likely where they got it.
Brown Swiss
06-03-2020 08:56:39
Krone is the best I've seen so far! My two cents!
paul
06-03-2020 08:36:58
Doesnít one company make a 3 blade turtle.
One makes separate segments that bolt together under each turtle and driven by shafts.
One company makes a large common oil pan under the whole cutters and gear drives the turtles from one common pan.
The various companies buy from these three, and relabel the machines as Ďtheirsí.
I think NH and NI/Agco swapped manufacturers a while back, itís pretty funny listening to the dealers promoting their design as better, when a few years before the other design was better when that is what they sold then.....
495man
06-02-2020 16:51:21
Enorossi makes mowers for Farm King (Buhler-Allied)
Sitrex makes mowers for New Holland.
Most of these are large Italian companies with US importers /re branding.
Jon Erickson
06-02-2020 15:58:08
Get a Kuhn. I agree.
danofarming
06-02-2020 15:33:40
Get a Kuhn. All of the rest are copies.
Copyright © 1997-2020 Yesterday's Tractor Co.
