Well today we baled hay with our 124 massey for the first time and things went well. I cut just enough to test a few bales. Bales are square and knotters worked fine which is what I was most concerned about. The only issue is that bales are 36" and weigh 78# They are like concrete blocks , you couldn't drive a nail into the bales. I have baked off the bale tension springs a bunch and we will try again in a few days as it is raining now.
The question I need help with is about the packer fingers adjustment. There are 3 positions a pin is placed in to make the adjustment. When I got the baler this pin was in the bottom hole and I have left it there. I can see that the bottom position causes a faster movement of the packer fingers and they go further into the bale chamber. I have the Massey operator book, it is a little light on information. It says the pin should be in the center hole initially but can be moved to a different hole for extreme conditions or abnormal flow. Thats all the information the book gives. Can anyone tell me what moving this pin changes in the baling operation and how the bale would be affected? Would this position setting affect bale density? Should I move the pin back to the center position? Thanks Bruce
