what model of AC plow is this?
Bevan
Is it worth fixing up to work or is it yard art for some antique aficionado? Missing one of the coulters, broken lift lever, no tires, no clevis hitch, etc.
Worst problem I see is the moldboard is broken off. Do you have the missing piece? You can probably get by with one coulter mounted to the rear plow. Used motorcycle tires will work on it. Is it free?
Get the parts off a mounted plow.Where are you located I have lots of those AC plows around,give you the moldboard parts.Lift levers off old AC cultivators might work on the plow.
Those old AC plows are about as scarce as hens teeth and if you don't feel like it advertise it and an AC collector just might want it to make look like new to display with his restored WC tractor at shows. Sure you could find the bottom parts you need on a snap coupler plow in scrap yard and lots of them went there.
Post it here on the YT forums for sale board up at the top L side. Its probably worth at least $50
Fix it they aren?t making anymore and a lot of implements went to scrap when the Price was high they?ll never make another one like it
Since my list of projects to fix up is already pretty full, I think I will let this one go. I am really more interested in a complete 2-12 pull type plow for my Oliver 60. I have a 50 series snap coupler I pull with my D17 so I am not without a plow. I will advertise for awhile. I have heard the #1 series is rare in two bottom, if this is a #1. Hope one of you is looking for a plow like this to restore in Iowa.
I have one just like this only one Bottom. Even missing a Tire and Ring for hitch to hook in/ What model would that be? No tail wheel but a land slide. My Grandpa had it fixed up nice and kept inside but after his passing my Dad somehow robbed a tire off and it been in the trees for 30 years. I decide that I better start taking care of it if it is Rare? cleddy
