Farmhand 22 loader
Hey all! My farmhand 22 loader on a tractor I just bought, lifts a little crooked. The left cylinder seems to laflg from the right, but when fully extended, the left one extends all the way and catches up. I was carrying a bucket of fill, and noticed that when I hit a bump, or a rough spot, the left cylinder piston seemed to move a lot in the piston from the right side. What are y'alls opinions? Thanks!
Since it is apparently not "leaking down" or leaking externally it would seem the issue is NOT with cylinder seals.
It's possible the cylinder that "lags" is bent and binding, or otherwise damaged and binding, or else the lift arms arms/loader frame is bent/sprung.
Needs new cups on the side that moves a lot . Mine does that when it?s time for new cups got one I need to redo right now
