Long story short, sold my house and I need to expedite a new shop build at new place. On top of that, I sold my only running dozer and excavator so I am a little screwed!
I only have my Case 1170, which has been pretty reliable for me. I have spent many many hours on a smaller 3pt tractor with box blade for fine finish work, and I have a small Deere with 6ft box available for final work, but I need a little more "balls" for bulk work. I will have to work up a pad for the building, add aggregate, cut in some drainage work, etc.
I know that case is not an agile bird and I will cuss because I don't have powershift, but it has 135HP and some as weight to get something done. Question is what would I want to shop for? I might prefer to go for a 3pt box but I have never seen one bigger than 6ft, AND those 3pt arms are insane close to the rear tires that I have concern a box may not clear. Then there are land leveler boxes. They could probably work but getting in tighter spots will be tough.
I also need to figure out a bucket for the Case high loader I have on it. I was promised a bucket when I bought machine, but that never happened. I ended up building a very custom rack plate up there that is identical to a forklift and I use off the shelf forks on it. I did that so I can chop a fork down and make another bale spear for it.
Guess all I am saying there is I might have to custom fit a bucket anyway, unless the fitment is standard enough that I can drop the mount plate and just hook up a bucket. ?
