urbancase
this will be the last post on this project till this summer as I have the axles made, mounted, painted and hubs and tires on. I flipped it today so it on its own wheels. I posted some pics of the pump and some measurements as I think destroke I think believed he said could give me a idea of the GPM based on the pump size. it came out a little taller but was unsure what I would end up with there, but we made a hitch plate that I can make a drop hitch for later the summer. I still have a little work to do for the carrier bearing for the PTO drive on the HYD pump, I did not notice before I mounted the pump to the frame but the u-joint hook up when you tighten it will make it run out on center I think I will find something better. by the end of the week I will have it out of the work shop as I need to get the 706 finished and my 1466 needs wire harness and needed a paint job and some other TLC. if anyone has and info replay back and thanks to the people that have replied as I do have enough info to get this set for tons per acre but would still like to know pump GPM.
thanks
thanks
