lime spreader 8
urbancase
this will be the last post on this project till this summer as I have the axles made, mounted, painted and hubs and tires on. I flipped it today so it on its own wheels. I posted some pics of the pump and some measurements as I think destroke I think believed he said could give me a idea of the GPM based on the pump size. it came out a little taller but was unsure what I would end up with there, but we made a hitch plate that I can make a drop hitch for later the summer. I still have a little work to do for the carrier bearing for the PTO drive on the HYD pump, I did not notice before I mounted the pump to the frame but the u-joint hook up when you tighten it will make it run out on center I think I will find something better. by the end of the week I will have it out of the work shop as I need to get the 706 finished and my 1466 needs wire harness and needed a paint job and some other TLC. if anyone has and info replay back and thanks to the people that have replied as I do have enough info to get this set for tons per acre but would still like to know pump GPM.
thanks
I can't help you with GPM, but I have to comment that I am a little suspicious that there has been some mission creep going on there.
You can measure the oil pumped for 30 seconds and times accordingly or measure the oil from one revolution then compare to other pumps for comparison.
