need help finding disc bog bearings
got a old king plow co disc bog harrow whatever they are called. it has 1 1/2 square axle and spool bearings, i am having no luck finding any that are 1 1/2. anyone have any leads where i might be able to find any? ill post a pic of them below.
If outside 1/2's of boxing aren't broken have you considered relocating boxing to some of the other unworn spools that haven't been utilized as part of the boxing?
(quoted from post at 11:56:06 01/10/20)
i thought that the spacing spools looked like bearing spools and thought about doing just that, but i figure the housing have to be wore out. the gangs have about 2 inches of play in them. do you think most of the wear would be on the spool?
(quoted from post at 12:08:25 01/10/20)
The boxings can have a lot of wear but still be functional. I agree with CN 1660 that those type boxings require a lot of grease
