PTO Sprayer Pump Stuck
C.Amick
I filled the pump with an automatic transmission fluid/kerosene mixture and am letting it soak. Would there be any benefit to removing the cover plate?
Be careful dont try to force the shaft to break it loose, I did that already once and the impeller where the rollers run cost more than a new pump.My 2 cents worth.
I've always just hooked it to a tractor and give it a hard jerk by hand after letting some ATF fluid soak in it for a while. I take it off and store it with atf fluid in it when its going to set for a while. I never had any luck rebuilding one and just replace it every 4-5 years. I just use the 6 roller pump so cost is about 110 bucks to replace and a rebuild kit is 30-40 bucks.
