Cross shaft for Bush Hog Shredder
John949
New User
My neighbor has a 10' Bush Hog model 2510 mower. He hit a rock with the LH blade and it quit turning. The failed part is the "Rubber element joint". Essentially, it's the coupling that attaches the LH cross haft to
the center gearbox. The only problem seems to be the rubber center is damaged. The dealer says the only fix to replace the entire unit for about $1,000 which is about half of what the shredder is worth. Does
anyone have a cheaper fix? Thanks
There?s a driveline outfit in Maryland that sells a replacement deal for that shaft (actually they offered one for a 3210) for about half that money. It was several years ago and I don?t have any more info at hand than that.
Have fixed 2 by drilling all the way through and putting 1/2 or 5/8 bolt through. We timed it 90 degrees from blade next to it.
