After my drive shaft broke in two early this year, requiring a new PTO shaft in my MF65 and bearings/seals on the Sidewinder 5x5 rotary cutter, I finally got things patched back up and took it out in the pasture tackling some 6' tall grass and weeds. It's been a wet summer so the grass is about as thick as I've ever seen, even more so given I had to skip the late spring cut due to the equipment issues.
After about one hour of normal operation, the cutter started really fighting the engine with the blades engaged. It wasn't sudden or anything, but started intermittently and quickly began getting worse. A glance behind me showed that with each blade rotation, there was a big clump of grass and a simultaneous extra-loud squeal. Risking further damage, I limped the tractor back to the garage without running the blades and noted no issues with the engine, isolating the problem to the spinning blades under some load.
I took a look under the cutter and noted NO visual issues, and that the bolts on the blades were tight. The stump jumper/blade assembly rotated FREELY by hand, so it's not a problem with the gear box. The blades are slightly worn but still sharp, if not a little banged up from years of use. Finding no obvious issue, I fired up the tractor and took a quick pass through thinner grass and the issue promptly returned. When the blades are spinning and not cutting grass there are no symptoms. But that the issue returns when cutting thin grass has me, no pun intended, stumped.
For you veteran rotary cutting folks, what would cause a cutter to bog down the engine and yield a loud squeal when under load? What can I check/adjust/replace?
